Ricoh mp161l offline on server
  • Mathewdlamini
    [Misc] Ricoh mp161l offline on server
    My ricoh MP 161L is showing offline on print server but online on display tried resetting printer and network switch did not help
    any ideas?
  • slot
    • 341
    try giving the copier an new ip adrress and change the port may work
    • Captain Scott
      • Dec 2008
      • 166
      Login to Web image monitor and see if IT dude has been adjusting SNMP settings. If no luck - go to ports tab in driver properties- click configure port and uncheck SNMP setting (forget the wording). Worth a try!
