Gestetner sc443
  • Jr Garza
    • Aug 2025
    Gestetner sc443
    Hello everybody, new at this forum hope to get help for future situations and/or help as well, needing some help on gestetner DSc545 SC443 code? just replaced transfer belt clng. blade assy. ??? thanks for your help cheers!!!!
  • hosennet
    • Mar 2007
    • 145
    Hi:
    Maybe try next way
    1.Check if the image transfer unit is correctly set
    2.Replace the image transfedr unit motor
    3.Replace the image transfer unit
    Good luck
    • Jr Garza
      Gestetner sc443
      Hi, thanks for the responce and I figured the sc443 it has to do with the encoder sensor on a roller, be careful with the screws, dont mix them up there are three long ones and 1 short that hold the encoder assly. cheers and have a good one
