Can we use Lexmark C510 toner on Ricoh Aficio SPC210sf
Its the same Print engine, so it should be possible. But i am sure, that the Cartridges wont fit mechanically. If you look on the cartridge from behind, you will see at the left side a black plastic Plug, this "codes" the Cartridge to the Manufacturer. You can try to gently pull the plug from the old cartrigde and put it on the new one.
If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
