mpc 5000 connectivity
  • katash
    • May 2010
    • 221
    hi guyz,please help on this,i have a client who i installed the postscript as he uses a mac.
    operating system,has refused to work and i dont know what to do.
    he's os is mac 10.6 he claims when he goes around the world the other products work with
    his laptop,any idea on what i can do?will appreciate.
  • rthonpm
    • Aug 2007
    • 2849
    What exactly isn't working?
    Does the machine have a PostScript chip in it? Without it, the driver is useless.
    • katash
      • May 2010
      • 221
      yep the postscript is installed,the printer says its waiting for the job and next it goes blank
      • nallard84
        • May 2010
        • 26
        check to see if usercodes are enabled
        • katash
          • May 2010
          • 221
          i did not enable them and by the way on microsoft is printing ok only on mac 10.6
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            How was the printer setup on the Mac?
            Did they run the installer program on the CD?
            The installer program on the CD only installs the Mac driver. They still have to add a printer from the print center, which should have the Ricoh driver as an option once they ran the install program off the CD.
            I've had the best luck adding LPD printers and then using the ip address and "print" for the queue name.
            • katash
              • May 2010
              • 221
              The driver was run from the c.d and the printer added from the print center, however upone completion of installation you could ping and get back a reply from the printer. so we decided to download the printers drivers from the ricoh website this being the latest drivers for mac o.s 10.6 but upon running the installer still the printer was unable to print. Any ideas as to overcome this issue.
              regards
              • copyman20
                • 207
                Try logging into the web-interface and check the PS setting in printer under the configuration link. If the "Data Format" is in "Binary Data", try changing it to "TBCP".
                That fix the same kind of issue I had.
                Good Luck
                • katash
                  • May 2010
                  • 221
                  thanks copyman20,will try and will let u know
                  • Choro1dal
                    • Jun 2008
                    • 176
                    Is AutoContinue enabled (usually set to Immediate)?
                    If so, reboot the MFD ask the user to send a job the check the printer error log.
                    Error code 91 would indicate that a mismatch has occured between the configuration of the device and those of of the application and driver and the job has been cancelled by the MFD.
                    • katash
                      • May 2010
                      • 221
                      thanks choro1,will do that the client travelled and i'm waiting for him eagerly,it works on his laptop he releases my chq!will let u know
