Error SC322 on Aficio 1035
  • Edutech
    • 16
    [Error Code] Error SC322 on Aficio 1035
    This machine is keeping on displaying error code SC322. At times it was disappearing after performing laser beam pitch adjustment (SP2-109-3&4) but now it has become a permanent condition. Please help.... What could be the cause of all this?
    Thanks in advance
    Edutech
    "Everything is okay in the end, if it's not ok, then it's not the end."
  • nos
    • Nov 2008
    • 78
    We used to see this alot. We have found that if you replace the ribbon cable to the ld unit it usually takes care of it.
    Good luck, hope this helps
    • Edutech
      • 16
      Hi, Thanks for this information. will give you a feedback once i try on this. again thanks.
      edutech
      • katash
        • May 2010
        • 221
        u need to service the unit even before you replace the cable,open up the laser synchronizer and blow,gud luck
        • guna2121
          • Nov 2009
          • 20
          sc 322 normally accurs when the LD unit mirror are dirty.try to clean up all the mirror inside the LD unit. sure can settle. Or get me back got another tricks
          • nqk
            • Sep 2010
            • 26
            you must clean those glass which are fixed in front of laser you may open with soldering iron if you any more help you may be call on 00923215625845
