MP161 with SC819
  • pspahr
    Toner Schlep
    • May 2008
    • 227
    MP161 with SC819
    Hey folks, checked the site for related sc819 but still had to post.
    I've a MP161 that inexplicably started throwing an SC819. I've replaced the Print/Scan SD, reseated the ram (but haven't replaced) and replaced the GW controller, all to no avail. I have a BICU coming but wanted to see if I missed anything. How best does one troubleshoot a SC819 or similar code?
    VectorLinux---Check it out!
  • Eric1968
    • 2458
    There is an RTB out about SC819 (RTB7). Upgrading the firmware should resolve the issue.
    SC819 (Kernel mismatch error) occurs if IP-FAX is not used for a long
    time while the Wireless LAN and fax are installed.
    • pspahr
      Toner Schlep
      • May 2008
      • 227
      appreciate the response, and I had seen that RTB. I don't have a wireless card in the system so I had ruled that out. Installed new PC133 128 ram stick today and resolved the issue.
      • patterson70
        • May 2010
        • 603
        Re: MP161 with SC819
        Hello, could you tell me where the 128MB DIMM is located? I am also having a SC819 and swapped controllers but the code did not go away. When I take the front plate off the controllers I see that both the original and the swapped controller have a slot for a memory card but neither one has a card installed. So, I am thinking the DIMM is somewhere else? I can't see where though. I also read that a 5990 report can help pinpoint the issue, I can print it out but I don't know where to look for the info on the report. Any help appreciated!
        P.S. I can swap out the BICU main board that is located behind the controller with a known good spare if that would be a possible cause?
        • Polarbear
          • Feb 2012
          • 1070
          What model is your machine? Base, SP or SPF?
          Normally the DIMM is installed if a print option is present. If the machine is a base model it would not have the DIMM.
          The DIMM slot is at the lower part of the controller, once the metal shield cover is removed.
          Press the GREEN button!!
          • patterson70
            • May 2010
            • 603
            It is a full SPF with scan, print, fax, copy. I wonder if someone took out the DIMM in both controllers then, I will get a DIMM and check it and see. Thanks!
            • patterson70
              • May 2010
              • 603
              I installed a known working DIMM from another working MP161 and still the SC819. Should I assume it is the BICU? Thanks again.
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
                • patterson70
                  • May 2010
                  • 603
                  I found out my problem, the controller did not have a memory card and so I installed a 128MB card but that still gave me the code. I installed a 256MB card and that worked.
                  • EmmanCorner
                    • Feb 2015
                    • 6
                    I really really wanted to try upgrading my machine's firmware. but regarding the process/procedure, i have no idea. i just hope that someone could have time to post it even just for this machine...because i am still hoping that one day my machine would be okay.
