Background on MPC2550
  • GhostInTheMachine
    • Feb 2010
    • 88
    Hey guys,
    I have a MPC2550 that has a blue background on copies only, not prints. It does this obviously in color mode, not b&w. I have adjusted the background sensitivity in user tools but it seems to have no effect. Swapping out the SBU also had no effect.
    Any ideas???
  • TonerMunkeh
    Professional Moron
    • 3865
    From both DF and glass?
    Hit it.
    • GhostInTheMachine
      • Feb 2010
      • 88
      It seems to be worse from the DF but it happens on the glass also
      • TonerMunkeh
        Professional Moron
        • 3865
        Mmm... bent scanner frame possibly. Try a spirit level on it. Could be a bad exposure lamp, CCD or SIO board too. Models of that age have rubbish parts in the scanner assembly.
        Hit it.
        • teebee1234
          • Jul 2008
          • 1670
          May possibly be an issue with the IPU where image processing is done.
          Also found this in the GKB, sound kind of similar where maybe the blue background is actually process black but is different in the fact that you say it is not occuring in b/w mode...
          [Problem]
          Background when ADS Mode is turned Off
          In Full Color the background is a process black, In Black and White mode the background is gray. With ADS on there is no evident backgrounding. When ADS is turned off and exposure is at the center setting, backgrounding is exhibited. Print Jobs and internal prints do not have background
          [Cause]
          The gray balance adjustment NV RAM Data has been corrupted and has reverted to the default value
          [Action]
          Reset the value of SP 4685 - 001 and 002, SP4686 - 001 and 002 and SP4687 - 001 and 002 to the value on the Factory Data Sheet.(Located under Jam Instruction Sheet on the Front Cover)
          If the Factory Data Sheet is not available try starting with these settings and fine tuning as needed.
          • SP4685-001 to -26 SP4685-002 to -26
          • SP4686-001 to -6 SP4686-002 to -6
          • SP4687-001 to -16 SP4687-002 to -16
          • kyoceran
            • 100
            a bit silly , but is the auto image density turned on, some machines come with this off, good luck.
            • Smee
              • Aug 2009
              • 178
              Im with the last post - check Auto Density is turned on. Ive had this on a couple of machines - totally threw me the first time.
              • teebee1234
                • Jul 2008
                • 1670
                That's true that auto density (ADS) may be off, but if it is it shouldn't leave a background when using plain white paper. That's why I posted the settings that may need to be changed.
                • kyoceran
                  • 100
                  as parts age and wear , as there is no automatic correction the image can become soiled, remember analogue manual setting.
                  • kyoceran
                    • 100
                    I must offer my apologies, i forgot about that scenario, have a good week
