codes sc390 and sc391 for afficio 2035
  • akbareshghi
    • Sep 2010
    • 261
    these error after forced supply toner executing appeared sc390
    after executing TD Sensor initialization this code appear sc391
    error code my afficio sc390 and sc391 please help me about this errors
    thank for attempt
    Color printing with lowest cost per page is my love.
  • Comatose
    • Jul 2010
    • 70
    The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
    • nqk
      • Sep 2010
      • 26
      td sensor error
      you must check develper unit in an other machine there you got problum if there is also same problum you change your td sensor.othere wise check hupper unit and clean it proply and last one check female conector of dv tank
      • maddog3k
        • Dec 2010
        • 3
        would this make copier reboot ?
        on a dsm415pf
        thanks
