gestetner mp 2510 multifunction
  • joegarzf
    • Jun 2025
    I'm having problems with this multifunction. When
    receiving faxes it will give me half pages or just a
    portion of a page. Then it'll come the report with
    error code like 06-00 or 00-88, or00-83. I suspect a
    memory prob, but not sure. Please help. Thanks
  • rthonpm
    • Aug 2007
    • 2849
    Try turning off ECM, it just causes more headaches than anything else.
    • teebee1234
      • Jul 2008
      • 1670
      It really shouldn't be necessary to turn of ECM. It's purpose is to correct transmission interruptions and errors. What you probably have is a noisy phone line. Check that first, clean the line connections and also try hooking up a handset to the wall jack and listen to the dial tone for noise. Most times it's the customers service that is the issue.
      • daveyt
        • 15
        Yes most likely the phone line with noise. We get the phone company to install noise chokes on the line to supress noise and this usually works
        • joegarzf
          Gestetner mp 2510 multifunction
          Thank you guis for helping. It is noise in the line. Told customer tu call phone company .
