Pro 1107EX WebImageMonitor
  • hmac
    • Aug 2009
    • 129
    Hello
    I work on a 1107EX, I can not access web interface.
    When I enter the IP address in the browser, it displays "error 404".
    Do I have to activate an option in the SP mode?
    Thank you
    _________________
    HMac.
    _________________
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    I don't remember offhand where it's at in SP mode, but you can turn it on remotely.
    From a command prompt, type "telnet <ip of machine>.
    Login at the prompt.
    Then type "set web up".
    That should do it!
    • hmac
      • Aug 2009
      • 129
      That should do it!
      What is the precise syntax of the command "Set up web"?
      For when I type "set up web" mark it "syntax error".
      _________________
      HMac.
      _________________
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        It's "set web up", not "set up web".
        Easy mistake to make.
        • hmac
          • Aug 2009
          • 129
          I followed your procedure via Telnet. The web service is
          well up, but I still can not access the web interface.
          I also install the following modules:
          - IPDS
          - PS3
          - Printer / Scanner
          I copied the applications IPDS and Printer / scanner on the PS3 card. But I can not print via IPDS, nor have access to the web interface.
          _________________
          HMac.
          _________________
          • G'Man
            • Feb 2010
            • 28
            SP5985 is set to 2 instead of 1. On board NIC limited access.
            G'Man.
            • teebee1234
              • Jul 2008
              • 1670
              If it's not what G'Man wrote, check this....
              SP5828-091
              091 Web (0:OFF 1:ON)
              Disables or enables the Web operation.
              [0 to 1/1]
              0: Disable, 1: Enable
              • copyman20
                • 207
                try putting in https://IP Address rather than http://IP Address. This means some one has turned on SSL.
