Ricoh mpc2500 operation panel caliberation
  • muaazgujjar
    • 67
    Friends,
    I am trying to recalibrate operation panel of MPC 2500,please guide me.
    How it could be done.Older Analogs Series 66/76/67 were done through "interrupt+C' and Aficio older like 401 were through "ALLCLEAR 1993 C X 5 #".
    thanking you in anticipation.
  • Leif
    • Jul 2010
    • 19
    Press "c", press 1993 , press "c" 5 times to open the Self-Diagnostics menu.
    • TonerMunkeh
      Professional Moron
      • 3865
      Don't bother calibrating it, it's failed. B223 9900.
      Hit it.
      • mikadonovan
        • May 2008
        • 2931
        Or B2231484
        NEVER ASSUME ANYTHING
        • Leif
          • Jul 2010
          • 19
          The new touch panels is free of charge from ricoh beacause the old ones has a production failure with the glue or something..It's only the touch screen that has to ble replaced not the lcd screen...
          • muaazgujjar
            • 67
            Thanking you all for the exact and relevent information.
            The unit is not under warranty and never sold by Ricoh Distributers in my country.Is it possible to letme try to recalibrate once.Please guide me to simulate the procedure.
            • turbojetboy
              • Aug 2009
              • 279
              It WILL be a waste of time - seen this hundreds of times - and if you do calibrate successfully you WILL be back within 48 hours with it out again. So dont waste yours or your customers time, just get a new touch screen and fit, it is a quick and easy job.
              • secretweapon23
                • Jul 2010
                • 69
                Even you replace the touch panel you'll still need to calibrate the new one. Here's the procedure:
                >press clear modes then(yellow button)
                >1993
                >then press clear/stop button 5x(red button)
                >press # button(touch screen adjustment), you'll see small circle on upper left portion of the screen then press it using any pointed tool.
                >after that you'll see again another small circle on bottom right portion of the screen then press it using pointed tool.
                > test the screen, see if mark will appear on the area that you press, then press OK.
                >exit and reboot the machine.
                hope you got it..
                Anyone who has never made a mistake has never tried anything new.....A.E.
                • muaazgujjar
                  • 67
                  THANK you SECRET WEAPON23, it was for older AFICIO 401.Does it work with MP 2500c
                  • jonezy999
                    just one copy??
                    • Feb 2010
                    • 952
                    yes, it works for mpc2500
                    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
