Aficio AP 3800C Error code SC 389
  • charelsp
    Hi folks, have an Ap3800C here with the error code SC 389. Does anybody have an idea what this means? Costumer says machine worked fine until now, magenta toner replaced recently. Thanks for any suggestion.
  • unisys12
    • 489
    SC389 - Development Gama Error, Magenta
    Possible causes...
    - Unsuitable toner density
    - Toner supply mechanism problem
    - Laser exposure problem
    - Image transfer problem
    Since you said that the magenta toner was recently changed, then I would go right there and you should find your problem. Make sure it is the correct OEM toner. Check that your pump is working properly and that the toner tubes are not clogged.
    Follow the magenta toner, and you should find your problem.
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Possible causes...
      Ditto!!
      Mystic Crystal Revelations
      • charelsp
        Ok ok, thanks guys for the helpfull information, got the shematics now although.
