Savin Service code 401-00
  • jackchro
    • Aug 2025
    After a manual feed jam I get a call service code - SC 401-00 (in the midst of self cleaning). How can I clear this - it should not be a real problem.
  • jackchro
    note to above - Savin 2400WD (wide format engineering copier)
    • jonhiker
      • 661
      401 ID Sensor Vsg Error
      The Vsg level was detected
      lower than 2.5 V two times.
      Clean the ID sensor.
      Check the ID sensor harness and
      connector.
      Replace the ID sensor.
      Replace the MCU.
      Replace the development unit.
      Replace the CGB power pack.
      i doubt it is any of the last 3, i would start by cleaning and checking the ID sensor.
