Savin C2525
  • glewisme
    • Nov 2009
    • 240
    Savin C2525
    Hi, I was wondering if anyone could help us how to perform a touch panel adjust on a Savin C2525.Any help would be greatly appreciated.
  • Jomama46
    • 2900
    TOUCH SCREEN CALIBRATION
    Press the following keys in sequence to enter touch screen calibration mode. C/M, 1, 9, 9, 3, C/S x 5, Enter. The self-diagnosis menu will appear. Press the enter key to select the Touch Screen Adj. Mode. The calibration screen will appear. Touch the upper left corner then the lower right corner of the panel using a pointed tool. Touch a few spots on the LCD panel and confirm that the marker appears on the screen at exactly the same location as where it was touched. If not, touch Cancel on the adjustment screen. Touch OK. Touch Exit and Execute to exit.
    But if its not responding at all, typically it will need a new touch screen. Fairly common on this model.
    sigpic
    A+; Network +; PDI+
    • glewisme
      • Nov 2009
      • 240
      Thanks it worked great.
