Gestetner dsm645 Meter
  • TommyH
    • Sep 2009
    • 118
    Hey guys, I have looked in the service manual and a web search but cannot find an answer. I would guess that means it can't do it but want to double check.
    Does anyone know if the above device can be broken down into department codes for billing and usage tracking? So for example, we have a copier used by several departments is there a way on this device to track each departments print/copy volume so they can be charged correctly per department? If so how can you print that meter report out, will they need a card reader of some sorts or can they just input a password or code to identify which department they belong to?
    Thanks for your help in advance.
  • Jomama46
    • 2900
    Starting on page 59 of the general setting guide it tels you how to set up "user codes" how to print the counts, etc.
    sigpic
    A+; Network +; PDI+
    • TommyH
      • Sep 2009
      • 118
      Thanks for the info. I was able to find the General settings guide and see exactly where you were talking about.
      • Jomama46
        • 2900
        Good man!
        sigpic
        A+; Network +; PDI+
