customer called with lines on the copy. The drum blade was worn out. SO I replaced Drum and Drum blade, transfer corona grid.
The copies are clean, but when copied any document with writing i can't see it on the copy. Everything else is dark and readable.
Any suggestions???
I can't seem to find any manuals for this machine. How can I reset drum settings?
Service codes?
Thank you.
Any suggestions???
Service codes?
Thank you.
