ricoh aficio 2018 pcu unit life
  • vaclav borc
    • Jan 2008
    • 75
    hi , please can you tell me how much of copies can work PCU unit aficio 2018 .
    My PCU did 40 000 k . Can it work 60 ?
  • Jomama46
    • 2900
    60k is the target.
    sigpic
    A+; Network +; PDI+
    • b003ace
      • Jun 2008
      • 78
      2018 PCU
      They will usually last 60-65K, occasionally 70K, BUT, the longer you run them past recommended, the more likely the dev drive gears will strip. Also, be careful when rebuilding, as any dev spilled in the gears will rip them up in about 10-15K. PMB12160K, B0399510, and B1219640 should be the numbers, if I remember correctly.
      • delosangeles
        • May 2008
        • 274
        Charge roller
        I like to clean the charge roller to extend the life of the drum.
        Trade like a tiger sleep like a baby
