I have 5 AFICIO units in field with same problem.The description of fault is as under:
All the units came with same status i.e power supply failure.I have repaired all the five power supplies power supply go to on position but voltage at 24 Volts points shows 20V to 22V .I have replaced FETs and all the suspecious capacitors but the problem is there.
I need schematic diagram /PCB layout of power supply too.It will be an extra ordinary favour for me.
Thanking you in anticipation.
