How is User Parameters accessed? Is it through User Tools or SP mode? And does anyone have instructions one how to get to the User parameters? That will be helpful. Any help appreciated, thank you.
Ricoh Aficio 2027 Fax Option
A limited amount of User Parameters can be changed through user tools (you can print out the list and see what switches and bits control what functions, like confirmation reports off/on). This is done in the fax settings of user tools.
The full gamut of bit switch settings can be accessed through service mode, you will need the manual for the full list with descriptions.
Printing the User Parameter list
Print this list to see the current User
Parameter settings. However, only
items of importance or often-used
items are included in the list.
A Press the {User Tools/Counter} key.
B Press [Facsimile Features].
C Press [Key Operator Tools].
D Press [Print List] next to [Parameter
Setting].
Changing the User Parameters
Important
❒ We recommend you print and
keep a User Parameter list when
you program or change a User Parameter.
❒ Do not change any bit switches
other than those shown on the previous
pages.
D Press [Parameter Setting].
E Select the switch number you
want to change.
F Select the bit number you want to
change.
When the bit number is pressed,
the current value switches between
1 and 0.
Note
❒ Repeat from step F to change
another bit number for the same
switch.
G Press [OK]Comment
Setting].
Important
pages.
want to change.
change.
1 and 0.
Note
switch.
G Press [OK]
Ditto. You beat me to it.Why do they call it common sense?
If it were common, wouldn't everyone have it?Comment
