Aficio 2035 problems of reset setting and restoring to factory default
  • akbareshghi
    • Sep 2010
    • 261
    My wrong setting:
    Other setting equal defaults of copier
    sp2103 LD power adjustment
    LD1(copier) initial=-10 current=60
    LD2(copier) initial=-10 current=60
    LD1(Printer/FAX) initial=-45 current=25
    LD2(Printer/FAX) initial=-45 current=25
    LD= Laser Drive
    2201 Development Bias adjustment
    Development Bias initial =560 current=660
    ID sensor pattern initial= 480 current=680
    2805 Developer initialization Execute
    2001 Charge Roller Bias Adjustment
    Copy initial=1500 current=1500
    ID Sensor Pattern initial=250 current=200
    2220 Vref Manual Setting initial=4 current=4.9
    After I run code 2207(FTS) , and code 2801 sequentially, the digits of 2220 and 2001 changed. But code 2201 that is related to develop bias adjustment not changed
    I never run 5801 or 2109 for restore to factory default setting but I want to do this . I wonder that if I run code 5801 and reset all copier setting , the problems in working with copier appeared . I donot know about how initialization of drum (developer) manually after running 5801 . please help me about this topic.
    Thank you for attempt
    Color printing with lowest cost per page is my love.
  • TitoMartines
    Do not worry! Do it. Before this print Complete SMC SP5-990-1. Then you have to input current volumes. TD and ID sensors will initial by Process control automatically after switch machine off/on .
    But the great topic is why you want to clear all memory?
