Hi I would like to ask if Gestetner 3502 can be connetcted on server 2003 64bit? I have connect the machine as printer and it worked but i cannot use the machine as scanner. I only use the server 2003 twain driver because there is no available driver on server 2003 64bit. i just don't know if the driver is not applicable that's why the scanner is not functioning. By the way I have tried the machine on windows xp, the scanner works fine. Hope you can give me some ideas on this matter. Thank you very much.
Gestetner 3502 on Server 2003 Server 64bit Scanner Problem
