Hello,
I am having issues with a Ricoh Aficio MP 161 Printer when scanning to a network drive using smb. I was hoping maybe someone has experienced a similar issue and could provide some insight as Ricoh's support on par with the worst I have ever dealt with. Any help would be greatly appreciated.
First off, I am pretty well experienced with this type of issue. I have tried everything I can think of. Feel free to get as technical as need be in any replies.
The Issue:
Ricoh Printer gives a connection error when trying to scan to a shared drive. Does not specify on the printer's screen or in the logs what the error is.
The Set Up:
Without making it more complicated than it needs to be. Printer has a static ip on the network - no conflicts. I am attempting to scan to a file server on the same local area network. It is a different subnet but connectivity is not an issue - at least for everything but this printer. I get a general connection error. However, I have another HP printer here which can scan to the drive with no issues - same settings and credentials.
I also have 3 printers in another location, same internal network, that can scan to the same smb path/folder with the same credentials. So the problem is isolated to this one device. Scans can be sent via Email using this Ricoh printer but not to the network path. For testing purposes, I am using the network admin account - which has full access rights - to rule out any odd permission errors.
I have tried using both \\ServerName\Share\ and \\IPAddress\Share\. No difference. I cannot find any new firmware on Ricoh's website for the Printer. I don't see why it should matter but the share path is not on the c:\ of the file server. The file server can ping the printer.
If anyone has any insight or ideas they would be greatly appreciated.
The Issue:
The Set Up:
