Hi I am having difficulty to get a MPC3300 to print the fax number on sent faxes. I have the customers name and their fax number installed, but only the name is printed on sent faxes. Have checked parameter settings, and cannot find anything that relates to the number, in case it had been turned off. The return test from our telco indicates that the correct number is installed and the format is correct. Can any help be offered?
