MP2000 DDST
  • Jomama46
    • 2900
    MP2000 DDST
    This is a new machine I set up today and even tho the BICU's firmware is up to snuff, I like to flash it anyway. The procedure is to insert the card, hold down the op panel button and turn the main switch on. I do that and the card is not recognized, Nothing, Nada.
    Next I reloaded the firmward on the Flash card. Same-o. Next I tried SP5827-1 (Program Download) at Execute I get "Loading error"
    Next I get another Flash card, load the firmware and try again. Samething. No response when I try to let it auto-detect and Errors when I use the SP mode.
    What can be the problem.
    It is a DDST and doesnt have the PCL option.
    sigpic
    A+; Network +; PDI+
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    • Jomama46
      • 2900
      Thanks iMind, this dog is the "lite" version and uses the old 4M Flash card instead of the SD card.
      sigpic
      A+; Network +; PDI+
      • iMind
        • Mar 2008
        • 1116
        uuum, I try and check it out.
        • iMind
          • Mar 2008
          • 1116
          BICU firmware updates is done on the back of the machine, right?
          • teebee1234
            • Jul 2008
            • 1670
            That may be it iMind. The printer/scanner update is done from the left side of the controller, the BICU is done from the rear (remove the small plastic cover with the plastic rivet). What say you Jomama?
            • Jomama46
              • 2900
              No there is a single slot on the controller box, on the left side below the RJ45. Definitely for a 4M Card. No small cover on the rear.
              sigpic
              A+; Network +; PDI+
              • iMind
                • Mar 2008
                • 1116
                sorry to say but there must be a slot on the back of the machine, right before the trays, the one under the nic is for printer firmware updades.
                • Jomama46
                  • 2900
                  I know you must be right, its the only thing that makes sense. However, the machine is shrink wrapped and ready to ship but since I will be the one to set it up on site, I will remove the back cover and check it out.
                  sigpic
                  A+; Network +; PDI+
                  • iMind
                    • Mar 2008
                    • 1116
                    OK, friends as always, hehehe
                    • teebee1234
                      • Jul 2008
                      • 1670
                      Here's the page with the graphic on where the card goes
                      • Jomama46
                        • 2900
                        Oh sh*t, its at the Bottom rear. I didn't even think of looking down there. Thanks teebee
                        sigpic
                        A+; Network +; PDI+
                        • teebee1234
                          • Jul 2008
                          • 1670
                          No problem, I didn't know any of this until you posted your issue. Your problem led to my education.
