Ricoh RW480 error SC-300
  • nnnghia1991
    • May 2025
    [Error Code] Ricoh RW480 error SC-300
    I have Ricoh RW-480 wide, frequent errors SC-300, help me!
    Thank!
  • teebee1234
    • Jul 2008
    • 1670
    Have you done any maintenance on it yet? Sounds like the charge is arcing, check the terminal blocks on the ends of the charge unit.
    From the manual.....
    SC300 D Charge corona output error
    Charge corona feedback
    voltage of less than 1V was
    detected for more than 200 s.
    • CBG power pack is defective.
    • High voltage cable is defective.
    • Poor connection of the power pack
    connector.
    • Dirty charge corona unit caused
    leakage.
