spc410dn
  • vespa geoff
    • May 2009
    • 37
    spc410dn
    hi all
    going to a ricoh spc410 tomorrow with a sc670 error code displayed i don't work on these much any help with this would be great . thanks
  • teebee1234
    • Jul 2008
    • 1670
    670 D
    Engine startup error
    The BCU failed to respond with the
    prescribed time when the machine
    was turned on.
    • Connections between BCU and controller board are loose, disconnected, or damaged
    • Replace the BCU
    • Replace the controller board
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • vespa geoff
        • May 2009
        • 37
        hi thanks for reply. when you say replace bcu, which board is that ,dont seem to see that in parts manual.
        • moonraker
          • 28
          Engine start-up error
          670
          [D]
          A command from the
          controller board is not
          received.
          �� Defective engine board.
          1. Replace the engine board.
          It could also be the controller board is not sat correctly.
          • teebee1234
            • Jul 2008
            • 1670
            Sometimes called the Engine board (EGB in this case), BCU stands for Base Control Unit-same thing). The part number is G158 5123 PCB: EGB-GP2A:Ass'y (G160)
            The controller is G161 5327 PCB: CTL: EXP: Sub-Ass'y (G160/G161)
            - Be careful looking in the manual, you have the G160 model. But as Moonraker said, first step is to reseat everything first (including the dimm on the cntrl bd).
            It's a little bit of an effort to get the engine board out the first time, I'm attaching the instructions in case you don't have them handy. The controller comes out the back with 2 thumb screws.
            • vespa geoff
              • May 2009
              • 37
              thanks
