Ricoh MPC 7500 - SC670
  • mearmi
    • Oct 2010
    • 350
    [Error Code] Ricoh MPC 7500 - SC670
    We are getting SC670.
    Can someone advise us. How to reset this code or its remedy.
    mearmi@hotmail.com
  • brodera
    • Aug 2009
    • 106
    Tryed to look it up in the service manual but dident find anything on SC670.
    • jonhiker
      • 661
      Engine startup error
      SC670 D
      1. Engine does not respondwithin 30sec after power on.
      2. Engine down detectedsuddenly during power on andwarm up.
      �� VBCU installation incorrect
      �� VBCU defective
      �� Sudden communication reset
      occurred between the VBCU and the Controller
      You shou8ld be able to reset it by powering the copier off completely with the switch on the front, not the control panel, wait 15 -30 seconds, and power it back up again.
      • JohnJay
        Jonhiker is correct in the description of the SC670. I would update the System/Engine firmware.
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
          This code is mentioned in the service manual a couple of times.
          Paul@justmanuals.com
          • E Winter
            Like jonhiker says: This code doesn't need a specific reset procedure. If it's coming back after turning the machine off/on you have to dig into this. Re-Connecting all cables/connector on the bcu and controller boards and rewriting the firmware is probably a good start.
            PS:
            Ask here to get in touch with the manual for free if there's a need.
            • printershelp
              • 10
              no need to reset sc 670
              the code mean that there is no comunication between the bicu board and the controller board. installing the bicu board firmware may help to fix the problem but sometimes is hardware issue from the bicu or controller.
              goodluck
              printershelp
