Savin 9220dl
  • ValSupply
    • Feb 2010
    • 38
    Savin 9220dl
    I've got a Savin 9220dl that I installed a PM kit on. Now the copies look good other than the top half looks great, but the bottom half is light. I've went back through everything to make sure make sure all connections are good and clean. ANY suggestions of what I could of possibly missed or over-looked would be greatly appreciated. Thanks!!!!!
  • Dumus
    • Feb 2010
    • 79
    Clean the poligon motor miror on laser unit.
    • mikadonovan
      • May 2008
      • 2931
      If you just did a PM, you probably cleaned the optics. Make sure you didn't knock a mirror out of position or lose one of the metal clips that hold them in place. (I think this model uses the clips. It's been a while since Iv'e seen one of these machines). Verify that the slit glass is clean. Dumus, this is an analog machine. No laser.
      NEVER ASSUME ANYTHING
      • Dumus
        • Feb 2010
        • 79
        Isn-t RICOH A200 : Savin 9220dl
        • Dumus
          • Feb 2010
          • 79
          Sorry, I see Savin 9220 : Ricoh 4022 , Well see the T/S , my be the brocken plastic house.
