Ricoh AF2090 often out SC495
  • china-yb
    • Aug 2025
    [Error Code] Ricoh AF2090 often out SC495
    Hi Ricoh AF2090 often out SC495 how should handle!
  • flo
    Engineer
    • Mar 2009
    • 44
    Clear or change the Tubes for Tonertransport, look for the Toner pump. Often the Seal inside is broken, and u dont get enough toner, mostley u can hear it, Look at the tonertransport from Tonerbank the coil must bring enough toner to the collector from where its go to the devbox, when u have problems with full tubes its better u give new one because problems will come back to you
    • hossam
      • Aug 2010
      • 70
      SC495: Toner Bottle Unit Error
      • Toner supply pump motor defective
      • Toner supply pump motor connector loose
      • Toner supply coil clutch defective
      • Toner supply coil clutch connector defective
      • Toner near-end sensor (in the toner bank) defective
      • Toner near-end sensor (in the toner bank) spring defective
      • Toner blockage in the toner supply pump or toner supply path
      • Toner hopper sensor defective
      • china-yb
        All too often, 3 days in clean, clean my head all big!
        • hossam
          • Aug 2010
          • 70
          check out used toner spring > on the toner bank it also out sc495
          • bastille67
            SC495
            SC495 has nothing to do with toner supply, what it does have to do with is the waste toner in the back of the machine. swing out the main pcb and controller, there is a small belt around the waste auger gear and drum flywheel, the tube that is attached to that is stopped up, take it off and vacuum it out and clean the rotation sensor as well and make sure the belt has decent tension on it, the spring loaded tension gear sometimes sticks. BE SURE TO GET THE BELT ON CORRECTLY ON REINSTALLATION!!!!
            • ucinn
              • Jun 2009
              • 383
              +1..seen this many times.. replace the three rubber hoses, clean out the augur going from toner bank to toner holder.
              • ucinn
                • Jun 2009
                • 383
                This is usually what it is on the 55, 60, and 70's
                • bastille67
                  OMG! I think i need new reading glasses, i thought it was a 2060, ugh. Please disregard my last post!
