2027 scan to folder
  • kentong
    • 15
    2027 scan to folder
    hi,i got 2027 machine,but don't know to install scan to folder,pls to help,thx
  • jonhiker
    • 661
    Scan to Folder Setup.pdf
    This document will give you that info. You can download the user manual from Home | Ricoh Global
    • rthonpm
      • Aug 2007
      • 2854
      You may also need to have custom firmware installed by a technician to allow scan-to-folder to Windows server 2003 (2008 server will be troublesome as well).
      • kentong
        • 15
        thanks a lot ,i will try to do
        • magauto
          rthonpm
          May i know what custom firmware that you are mentioning here? Cause Im having problem to connect to Windows Server 2003 version too...
          • rthonpm
            • Aug 2007
            • 2854
            Ricoh issued custom firmware to resolve issues with packet signing that was included in Server 2003. The firmware is only available to authorised Ricoh technicians.
            • Ralph S
              Turn Off SMB packet signing on the 2003 server. It will expose the server a bit to improperly formed IP packets. It will be up to the customer to decide.
              • rrowens
                • Jan 2011
                • 17
                I hope this is the same on a km 4050. I have a customer after 3 years decided he didn't want to scan to e-mail anymore and want to scan to fold. Thnaks for the info.
