Error E 54 or 3 54 ricoh FT 3713
  • henk52
    • Aug 2025
    Hello
    A have a error E 54 or3 54 from a nasuatec/ricoh FT 3713
    You can olo skype whit me henkie_20054
    M vr gr
    Henk from Holland
  • Patish
    • Aug 2008
    • 66
    • Eric1968
      • 2458
      The temperature of the fusing unit, measured by the thermistor, does not rise 20 degrees within 12 seconds. Check the thermistor. When the fusing unit is OK and the message returns after resetting the E54, the EPROM (which contains the firmware of the machine) needs to be replaced. But I don't think you can get an EPROM for such an ancient machine.
      Eric (also from Holland)
      • henk52
        Hallo Eric
        Kan ik u bellen
        Gr Henk
        • henk52
          Hallo Eric
          Kan ik u bellen
          Gr Henk
          • Vollegaaz
            • 73
            Was een oud zeer op die toestelletjes.
