Savin 8030 PCU unit
  • ValSupply
    • Feb 2010
    • 38
    Savin 8030 PCU unit
    I have a Savin 8030 and have used the 411019 PCU unit but also know that the recommended PCU unit is B2050151. Can anyone tell me if the 411019 comes with developer and the B2050151 does not? The 411019 unit is about $100 less expensive and works ins the same machines.
  • Jomama46
    • 2900
    type 1027 PCU will work in that machine. It comes with everything, the new # is 411020.
    sigpic
    A+; Network +; PDI+
    • E Winter
      Ricoh does not recommend to swap the complete B2050151 PCU - you have to refurbish the PCU with a maintanance kit (new drum, blade...). With a Kit you should lower your costs a lot but we are using the Type1027/EDP411019 PCU as well because they are even cheaper compared to the costs for your time and a mainantance kit
      But like I said - if you do it by the book you don't have to swap the complete unit.
