MPC2550 Internal Finisher Won't Staple Correctly
  • Ricoh-ono
    • 338
    Recently had a problem with an internal finisher not stapling the paper correctly. It couldn't pull the paper back in to jog it properly before stapling. The conveyor belts (this is what the manual calls them) were not making good contact with the paper. There are these white plastic "holders" that have to be trimmed or filed in order to improve the belt's contact with the paper. After trimming these holders the problem was solved. Hope this helps anyone who may be fighting this issue.
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
  • totoro
    • 568
    Great tip. I'll have to remember that.
    Totoro
    • rsyarcia
      Hair Straightener Tech
      • 711
      tnx for the info..
      Nobody is perfect..
      • zed255
        How'd ya manage that?
        • 1024
        Done this several times already, good tip for those not in the know.
        • Daveyboy
          • Feb 2011
          • 18
          Re: MPC2550 Internal Finisher Won't Staple Correctly
          Brilliant thank you
          • Dejavu
            • Jul 2012
            • 1
            • tinfox
              • 317
              Two HOURS later I thought I should search online...
              Thanks. Fixed now
                • 37533
                As the ribs on the conveyor belts wear down, you will eventually end up having to repalce the belts. Good Luck.
                Also, paper curl can cause bad stacking on these dogs.
