Ricoh Aficio 180 Code SC 547
  • vonhetcchtel
    • 42
    [Error Code] Ricoh Aficio 180 Code SC 547
    Hi, Good day, I have a customers Ricoh Aficio 180 which is displaying error Code SC 547. Please help me with the solution because it keeps coming.
    Thanks.
  • Eric1968
    • 2458
    The zero-crossings of the AC power are not properly detected. Could be the Power Supply, or the BCU-Board.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • vonhetcchtel
        • 42
        Hi,
        Could the problem be solved if I change the power supply or what else can I do to solve this problem?
        • TonerMunkeh
          Professional Moron
          • 3865
          First off, check the power supply the machine's plugged into. I've had dirty power cause cross signal errors before. If that fails to fix it, power supply. If that fails, BICU board.
          Hit it.
          • lky1978
            • Mar 2009
            • 483
            CHECK THE POWER SUPPLY, possible cold solder joints.
            • spacedust
              spamanamamammmmm
              • 47
              try turning on fuswer soft start,think its in 1/108......
              also might need to reset with sp 5/810
              dont forget to press the hash and shde key after selecting "1"
