Ricoh Aficio 700 "Copies unbalanced"
  • kalaris
    • 70
    Sorry for the bad translation. In the print copy is perfect, in copying the lower side and unbalanced, very clear, almost white, with irregular features.
    I clean white plate, optics, substitute the halogen lamp, set the scanner (4428) but varies but does not resolve. It has happened to someone?
  • ponto700
    • 144
    can you please scan and attach here the copy.
    • zed255
      How'd ya manage that?
      • 1024
      Check for a chip in one of the mirrors. They rest in the carriages against raised metal nubs and I have seen the mirrors chip in those areas causing image quality issues when copying.
      • kalaris
        • 70
        Attach a copy as soon as possible
        • mikadonovan
          • May 2008
          • 2931
          Did you clean the shield glass above the PCU? Toner can get on this glass causing light areas on the copies.
          NEVER ASSUME ANYTHING
          • kalaris
            • 70
            Yes, maybe it's the first thing I did
            Digita il testo o l'indirizzo di un sito web oppure traduci un documento.
            Annulla
