MP4000 SC141 errors
  • df3036
    • 109
    [Error Code] MP4000 SC141 errors
    Has anyone else been having SC141's on these? Bulletin 45 says that the failure rate is about 0.1%. I have 2 doing it every now and then. I have not changed the BICU yet as it has still been resetting so far but sometimes after 2 or 3 power cycles.
    Any ideas
    Dave
    Kittens give Morbo gas.
    A+, Network+, Server+, PDI+
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Just hope you can keep this account...if you can make it from pm to pm without a service call, I will buy you a pint ;-)
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
