Sharescan with Aficio 2035esp using twain driver probelm
  • mdtrinh
    • Aug 2010
    • 68
    [Misc] Sharescan with Aficio 2035esp using twain driver probelm
    Is anyone having this problem?
    I am using Ecopy Sharescan with Ricoh type 2045 twain v3 and it can not scan with mix original document. There is no mix original selection in administration setting or scan setting. Legal size document will only scan missing the bottom portion when select letter size scan size. This is not a problem when we scan with Adobe Acrobat software. By the way, it work fine with Canon DR 3060 scanner even select letter size.
    Cheers!
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    You may be forced to scan everything in as Legal size.
    While there will be 3" of blank space at the bottom of Letter size pages, at least you won't be losing any image.
    Not all applications play nicely (or equally) with all TWAIN drivers, as I have (quite painfully) discovered.
    • mdtrinh
      • Aug 2010
      • 68
      Thanks!
      I also learn that with Aficio 3045 it scan double side even we set to single side selection beside no auto size selection.
      Cheers!
