i have a ricoh 3245c that has a 1mm image offset when printing black and white only. is there a correction to this problem? thanks,
ricoh 3245c dual laser alighnment
Tags: 3245c, affects, black, black and white, black and white only, copyi, dirty, dual, image, jpg, laser, offset, printing, registration problem, ricoh, specifications, subscan, white
Have you run colour registration adjustment and ACC in user tools? First place for an end user to start. If that doesn't work, call a tech.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
i look after quite a few of these machines and find them quite good. never seen this issue before. if i sent you a pdf you would definitely see the problem. it make text blurred.ive always been able to manually adjust colour registrations when needed but this doesn't seem to be a registration problem, more to do with the dual beam laser in the black and white mode.Comment
If it's in the subscan direction then the ld unit wouldn't be the problem, it affects main scan -front to rear. The subscan is a product of the drum rotation, so I would look at the black drum/dev drive. Is the 'offset/blur' repeating itself? If so you should be able to determine what component is causing it by measuring the distance between them (print a test pattern on 11x17).Comment
