[QUOTE=manuals4you;181617][COLOR=blue][B]This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
Turn the main power switch or
main power switch off and on.
SC491
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
High voltage leak
Broken harness
Defective drum unit or development unit
Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
SC491
development.
High voltage leak
Broken harness
thanks .. all ..
Is the front door of the units Develop. not close properly.
