two network cards in one ricoh?
  • concretefingers
    • Aug 2025
    [Misc] two network cards in one ricoh?
    Hi
    a sales man has just asked me if two nlc cards can go in one one ricoh(mpc2800/3300/400. So two different networks can print to it?
    many thanks
  • mrwho
    Major Asshole!
    • 4299
    As far as I know - and I could be wrong, someone correct me if that's the case - if you install another network card (gigabit or wi-fi) it will disable the built-in network card. So only one card can exist at a time.
    A solution for that could be installing a print server on the USB port, then one network would print via NIC and the other via USB.
    Other solution - not related to us copier techs - would be for the IT guys to bridge both networks so they both could see the MFP.
    Mascan42
    Ibid
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Perfectly said, MrWho, and exactly right.
      Keep in mind that if you do utilize the USB port, it's for printing only.
      • Lotec
        • 97
        We have connected two networks to one machine. We used the regular nettwork port and one using a parallell printer port and a HP jet direct box. Think that worked fine.
        Can't remember how/what we did with scan to mail though..
        btw.. is it not strange that the new MPC3001/4501 models don't come with a standard USB slot in front? Seems like all other models come with this option as standard now.
