2232c creaks/colours out of position/vertical lines
  • ash_572
    • Oct 2008
    • 523
    all the drum units and dev units have been replaced. and the transfer belt and blade.when i make a full colour copy the machines most times makes a creaking noise (like floor boards) and when it does, the colours are out of position and i get lots of different coloured lines from top to bottom. (not in the direction of the feed). this mainly happens on a3 and sometimes on a4. printing is perfect in b/w with no problems. the white gears on the back of the drum have all been replaced including the stepper motor that drives the gears. ive enclosed a sample
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • pbbsinc
      • Nov 2005
      • 92
      My first guess is that one (or more) of the bushings on the rollers in the transfer unit are binding. Had a 3245 do the same thing not long ago. Would work fine with A4 but not with A3. Made the "creak" sound you describe.
      We also see the retainer clips on the ends of some of the rollers crack or otherwise fail. the ones on one end (front, I think conduct bias, & can be swapped with the opposite end if you don't have new ones (or unti you do).
      • XXX
        • 69
        My guess is that you have a problem with the cyan drum unit. It looks like a charge or bias leak.
        Try swapping the yellow & cyan drum units around, just for fun.
        • Polo-022
          • Sep 2007
          • 484
          Fuser replacement is very critical also...
          Check the Non Default list and re-input the values
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            Best to run motors in sim mode to see if you can isolate noise. Since the K dev shares drive with the fuser it could be fuser that is causing issue. May also be transfer unit though.
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • ash_572
              • Oct 2008
              • 523
              thanks for the reply.its definitly not the fuser unit. and the cyan drum unit was already replaced and swapped around.
              • XXX
                • 69
                It sucks that you have already replaced the belt, but I'm leaning towards the ITB unit as the next item to replace.
                The part number for the assembly is B1013810
                • rthonpm
                  • Aug 2007
                  • 2849
                  Take a look at the registration roller as well. I have had a bunch of those need to be replaced in the past as you get that nice creaking sound and the A3/DLT issue as well...
                  • benn84
                    • Jan 2011
                    • 26
                    did this problem ever get resolved as im having a similar problem on a 3228
                    • Gift
                      • Mar 2011
                      • 2458
                      You can try to disassemble and clean the entire transfer unit including every single (non-ballbearing) bushing. You should also take a close look at that black bias roller that is running above the belt (where the paper comes in from the registration). If the transfer belt looks unhealthy you might have to swap it. - depending on the overall copy counter you might have to go for the entire transfer unit (probably not worth the money though)..
