Ricoh Aficio 1075 very dirty background every morning.
  • tinnyjay
    • Oct 2009
    • 655
    Hello!
    From 2 weeks my Ricoh AF1075 every morning i turn on,print out a very dirty background (all surface of paper).This can be repaired only after executing SP 5801-1 and SP 2801-1.
    After factory reset and initialization of TD sensor,every copy is perfect.
    How values can be lost such a way?
    Developer,Drum,Cleaning Blade are almost new.Just 30k-40k.
    Sorry...the problem happens if copier is set to Energy saver.
    Can u help me please?
    "Who loves the roses,must also bear thumbs"
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    is the toner separation filter good on the dev unit? if not, replace it and repl dev
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Polo-022
      • Sep 2007
      • 481
      SP-2001-1 to 6. Are these values set to default or not???
      • tinnyjay
        • Oct 2009
        • 655
        All these values are default.
        • Jomama46
          • 2900
          overnight condensation on the drum/optics?
          sigpic
          A+; Network +; PDI+
          • teebee1234
            • 1670
            Had this problem on an older model of this size, turned out the erase lamps were flickering when first turned on in the morning and then would stabilize. Replacing the erase lamp fixed it. This model doesn't have erase lamps (except pre-transfer, don't think that would cause it if it fails). I side with Jomama46, sounds like an enviromental issue. Try disabling Auto Off and energy saver mode if they're on and see if that makes a difference.
