MP C 4500 Black Drum Switch
  • iscott
    • Mar 2010
    • 344
    Can someone post the instructions or a link to the procedure (one with pictures preferable?)
  • aabarnes1
    • Mar 2009
    • 620
    You must grind down the corner of the connector on the black pcu to match the angle of the colour connector. It is a very simple and quick procedure but you must be careful not to grind off too much or indeed too little.
    Grant me the serenity to accept the things I cannot change.
    • teebee1234
      • Jul 2008
      • 1670
      It's more important not to grind off too little (go at least half way through the metal pin). If you don't shave enough off and push it in you will knock out/break the female receptacle in the rear- pull out a color pcu for comparison. That will require replacement of the whole toner supply unit as the harness is not available individually (stupid, I know). I use a flat bastard file but if you have a lot to do you may want to invest in a Dremel grinder, it will pay for itself. The MPC4000/5000 require a wire position swap in addition to filing the connector, search the threads for the directions on that one.
      • XXX
        • 69
        New charge rollers are sticky, so if you get any repeating dots after installing a modified PCU, wipe down the charge roller.
        Chances are good that some of the filed material will find its way to the roller.
        • Old Guard
          • Jul 2010
          • 17
          If you damage the socket in the machine (happens quite often) you can look forward to having to replace the whole drive unit, to which the sockets are connected. This would take about half a day!
          • brodera
            • Aug 2009
            • 106
            Picture and how to do. Notice at the grinding part, you dont have to remove it. Just be gentle while you grind, it can break very easy.
            • butcher
              • 48
              K PCU to Colour
              A sharp pair of side cutters is faster than a file and will draw less attention from your customer than a file!!
              • verderacer
                • May 2008
                • 158
                I have never had a customer question me as of yet and I have replaced and performed the mod to over a 100 of these. The times when a customer has seen me doing it they have never said anything as of yet.
                Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
                MCSE/CCNE/ENS and other crap...
                • mrwho
                  Major Asshole!
                  • 4299
                  Re: MP C 4500 Black Drum Switch
                  I'm looking at an MPC4500 and I'd just like to confirm: the procedure is still the same (grinding the back connector and swapping the two front wires) or did anything change for this model?
                  Mascan42
                  Ibid
                  • Ollie1981
                    Toner Monkey
                    • Mar 2008
                    • 418
                    No wire swap with the 4500, just grind off the corner.
                    • iambeetle84
                      • 21
                      yes, just grind off corner. I use my pocket knife. I have never had any customers question what im doing.
                      • Ianizer
                        • Jul 2011
                        • 380
                        This is a revelation to me! Awesome!
                        I'd been removing my old color PCU connector and wiring assemblies (yes, derouting all the way across the back!), and swapping it to my new black (color-wink-wink) PCU... And Ricoh has become tres tricksy with this of late.
                        As far as nosey customers: I'm saving you money is what I'm doing. You don't have to thank me.
                        -I
                        My name Peggy.
                        You got problem?
