disabling manual input for Scan to Email: possible?
  • pbbsinc
    • Nov 2005
    • 92
    I have a customer who wants to ensure that employees cant scan docs to their personal email (afraid of their own wiki-leaks?). They have aficio 3030s & a 3545
    Is there a way to disable the manual input function on email scanning? I didn't think so & couldnt find anything, but one of you guys may know the trick.
    Thanks in advance...jay
  • jonhiker
    • 661
    If your customer is using an Internal Exchabge server, then the administrator can restrict email scanning to internal(company) email addresses. I have seen this a few times.
    However, it would not restrict them from emailing to their personal addresses from their company addresses.
    • zed255
      How'd ya manage that?
      • 1024
      On the email server it is called 'relaying' and i believe it is possible to restrict relaying in various ways. I've been in environments where the workers PC's can send email off the domain (ie the message is relayed) but the copier could not.
      Did you have a look to see if 'extended security' setting are available under system tools? Administrator authentication may need to be on.
      • jonhiker
        • 661
        [Did you have a look to see if 'extended security' setting are available under system tools? Administrator authentication may need to be on.[/QUOTE]
        Update: Zed, you are correct. Turn on Administrator Authentication. Then User Tools>system settings>admin tools>extended security. you can turn off manul input.
        Of course, that does not stop them from using their email to relay to an outside email.
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          Authorized email then send it from there... and so on, hehehehe. are you russian, turkish or moldavian, LOL
          • XXX
            • 69
            Make photocopies and walk out the door with them in your pocket.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              If this is that much of a concern for the customer, and they;re willing to spend a few $$$, adding GlobalScan could accomplish this task nicely, along with adding a few features.
              • nmfaxman
                • 1702
                Set up user codes on scanning to monitor usage.
                Turn off admin e-mail default. Makes them use their e-mail as sender and shows where it went to and how many pages.
                Lockout address book from control panel and give Web Image Monitor a simple password.
                It won't keep them from manual input, but will give a true accounting of what is transmitted and who sent it.
