There is no folder selection in address book management set up for scan, it only has e-mail select, no smb or ftp at all. It is a AF2045S/P model. Firmware (1.03, system 1.06, engine 2.11b panel 1.07, nib 4.04). Please help!
Thanks!
Thank for quick reply.
- No, there is no folder section for the path in address book management.
- At the scanner screen, there is no selection between e-mail/folders on the left side.
Cheers!
You don't. The controllers are different and not swappable AFAIK. Even if you could the controller would likely be cost prohibitive for simply gaining SMB scanning.
