Aficio 3228c colour registrtion.
  • fotocom
    • Nov 2008
    • 96
    Greetings..I hve a Aficio 3228c mfp with the colour registration slighlty off. When i try to do an auto registration in maintenance it fails to complete. Everything else is perfect on the machine apart fom the registration. Any ideas please?
  • Eric1968
    • 2458
    Make sure the id-sensors, transfer belt and the drive rollers are clean. Did you already tried SP5-993-039?
    • jonhiker
      • 661
      alignment.pdf
      Here is the bulliten on adjusting alignment and registration. As Eric says, make sure the transfer unit is clean, you may need to replace the image transfer belt, and do 5-993-039 several times. You may need to manually adjust the registration.
      this has worked, as had replaceing the transfer unit, and even the laser.
      • fotocom
        • Nov 2008
        • 96
        Appreciate the bulletin and the tips. Will give it a go tomorrow. Cheers...
