Changing Destination Server Ricoh 1075
  • hmhill17
    • Aug 2025
    Had to install scanrouter pro lite 2.0.6.0 on a new server because of a corrupted installation and an apparent inability to uninstall it because of the corruption. The scnarouter install and settings restore worked no problem. Only problem is changing the settings for the destination server. I can't change it in the tools/system settings/file transfer tab on the 1075. I can't find it in the web utility accessed via IP. How do I change the destination server? I looked through other posts, but nothing seemed to answer the question for me.
  • jonhiker
    • 661
    It is changed in SP mode. SP 5845-002
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Good call on the SP mode!
      I had to do one last year the very same way. All the clear modes had no effect.
      • hmhill17
        Thanks for the info. I actually got it changed through scanrouter. Of course, then I found out the version of scanrouter I have doesn't support UNC or mapped drives, so that's a new set of problems.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Sounds like you're running Scan Router Lite.
          • hmhill17
            Yes Scanrouter Lite. And buying anything else isn't an option so
