Just a general Question
  • brodera
    • Aug 2009
    • 106
    What are to cause of toner explosions "Huge toner leak" in the machine?
    I hope we can fill up some information for this kind of situation.
  • JR2ALTA
    • Feb 2010
    • 2028
    It's not that general. It's a cause and effect situation. It would help us if you gave the machine type. There's a good chance it's developer leaking and not toner. To test, developer will stick to your magnetic screwdriver.
    • brodera
      • Aug 2009
      • 106
      Well its in these series MPC20/25/30/35/4500. And i just took out the "Yellow toner" in this case and it was leaking in the whole machine. and i just want to know what causing this. Maybe a incautious customer
      • dickierock
        • 252
        That sounds kinda strange to me,they normally run clean enough for us..are they genuine toner carts?/refilled?
        • Eric1968
          • 2458
          We only use genuine toners and we have no problems with leaking bottles.
          • rsyarcia
            Hair Straightener Tech
            • 711
            always check the toner bottle.
            Nobody is perfect..
            • BLADE
              former propeller tester
              • 478
              could be developer has crashed with time even tho it hasnt done the miles. does the machine have a high black count and low colour count ?
