Gestetner 3222 : Print out problem
  • xtraez
    • Jun 2008
    • 42
    [Misc] Gestetner 3222 : Print out problem
    Hi,
    Happy New year to all Copytechnetian..
    I need help on the below issue. There is print out not even. See the image I attached to this thread. You can see inside the rectangular box on the scan image below and also the print on left side darker compare to right side.
    Action taken:
    1. Service PCU unit, change new drum and clean blade -- Still Happen
    Please help.
  • TonerMunkeh
    Professional Moron
    • 3865
    These PCU's can only be serviced once or twice before they need to be replaced. Bung a fresh PCU in it, give it a good vac out, clean the laser slit glass and replace the transfer roller. That should be you sorted.
    Hit it.
    • tinnyjay
      • Oct 2009
      • 663
      Originally posted by xtraez
      Hi,
      Action taken:
      [ATTACH=CONFIG]7673[/ATTACH]
      Please help.
      Its not problem of "writing" on paper,but not good toner+developer feeding.
      Check magnetic roller on dveloper unit.
      Is it filled with developer when you turn the gears?
      PS:Just to know.Whats that language on the newspaper?
      "Who loves the roses,must also bear thumbs"
      • xtraez
        • Jun 2008
        • 42
        I will check again the developer unit.. Can you advise how to know the problem coming from developer?
        p/s It's Malay Language.
        • xtraez
          • Jun 2008
          • 42
          I hard to replaced the PCU unit's. It very expensive, so we need to recond/refurbished until the end.
          Thank you.
