printer board similarity on 2035 and 2045 ricoh
  • akbareshghi
    • Sep 2010
    • 261
    [Misc] printer board similarity on 2035 and 2045 ricoh
    I have one printer board that work well on 2035 with 64MB flash
    I want to but one 2045 copier without printer board . if I do so , and replacing mine printer board on 2035 to new copier 2045 , is it work?
    Please help me about ?
    Thank you
    Color printing with lowest cost per page is my love.
  • Jomama46
    • 2900
    The 35 and 45 use different controllers. At least the part numbers are different.
    sigpic
    A+; Network +; PDI+
    • zed255
      How'd ya manage that?
      • 1024
      The print/scan DIMM is the same in a 2035 and a 2045 and requires at least 128MB of RAM be added. The NIB option is also the same. The 'enhanced' versions, the 2035e and 2045e use a different print/scan DIMM and NIB from the non-enhanced version but are compatible between a 2035e and a 2045e.
      As Jomama46 has mentioned, the controllers are different for each model.
